Could any one help me regarding this. I've settings up my Apache tomcat 6
and mysql but I have not luck so I tried using the ODK Vm. It works
perfectly but the problem is I really need to configure the mysql
connection of ODK to our own mysql database. Is there any way to
reconfigure or modify the mysql connection settings of ODK inside of the
VM.
Easiest way to accomplish this is to stop using the VM and use the
regular Tomcat install. That install process will ask for the IP and
port of your MySQL server.
perfectly but the problem is I really need to configure the mysql connection
of ODK to our own mysql database. Is there any way to reconfigure or modify
the mysql connection settings of ODK inside of the VM.
"ODK Developers" group.
