Hello. In an attempt to remove the Google Apps piece of the setup I
am attempting to run Aggregate on a Tomcat. I have it setup, I have a
form loaded, but I can't seem to figure out how to properly configure
a Collect client.
I am testing on a private network and the server is
10.100.100.99( only http)
Do I use the 8080 port in the phone collect server?
Do I need need to setup a user in the Agg server as a data collector?
Is there a walkthrough?
Will this write data collected directly to mysql?
Yes, if you have configured the server to operate on port 8080, then you
would configure Collect to use port 8080.
Yes, either you need to configure the server to allow anonymous access, by
granting the anonymousUser Data Collector privileges, or you need to create
an ODK user with those privileges, and specify that user during the
configuration of ODK Collect.
a Collect client.
