How do i build in a skip if the string length is 3. Example: if somebody types sss in the text field question then it should skip to the next question.
Hi @Rod
I don't understand your case well. Could you describe it better? Do you want to allow navigating forward only if a user types three chars in the current question?
Thank you Grzegorz.
Sorry for not explaining my question clearly. below is my simplified question.
Q1: text ( If string length is 3 skip to Q3)
Q2:
Q3:
Thank you so much for your help
Ok, now I understand.
Here you go: stringLength.xlsx (5.6 KB)
