Hi
I was designing an XLS form. I want to use group which I have already created into other group also. For eg if the group name is a then I want to use it in group b as well as c. Is there a way to do this?
Hi
Sure,
If this is just calling from group into group (or group into repeat loop,
but not repeat loop into repeat loop, see below for that)
${variable}
should plug in the previous responses in the appropriate spot.
If you are in a repeat group referencing another variable within that same
repeat group, you can use relative references
../variable
And if you are in a repeat group and calling a variable from another repeat
group you can use an absolute reference with a repeat qualifier (item in
square brackets)
/formname/group1/repeatloop1[position() = 1)]/variable
/formname/group1/repeatloop1[position() = position(current()/..)]/variable
Hope that helps.
Jason
