I am working on a form where a note should be displayed if it meets the
correct conditions. my condition for relevance is:
Note 1
selected(${q2}, '5') or ${q4} < 18 or selected(${q5}, '0') or ${c1} < 3 or
selected(${q7}, '1') or selected(${q8}, '0') or selected(${q9}, '1') or
${audit_c} < 4 and (selected(${tp}, 'A') and selected(${q1}, '1'))
Note 2
${audit_c} < 3 and (selected(${tp}, 'A') and selected(${q1}, '2'))
Note 3
${audit_c} > 3 and (selected(${tp}, 'B') and selected(${q1}, '1'))
Note 4
${audit_c} > 2 and (selected(${tp}, 'B') and selected(${q1}, '2'))
What i need it to do is show if either of the following, I am using note 1
as example:
If user has selectted:
q2 = 5 or
q4 less than 18 or
q5 = 0 or
c1 less than 3 or
q7 = 1 or
q8 = 0 or
q9 = 1 or
audit_c leass than 4 AND
the user has selected a combination of tp = A and q1 = 2
I would then like to it display note 1, however it displays all the notes.
So I am assuming I must have a syntax issue of sorts relating to the last
part which references the combination. I know the fist part is working (selected(${q2},
'5') or ${q4} < 18 or selected(${q5}, '0') or ${c1} < 3 or selected(${q7},
'1') or selected(${q8}, '0') or selected(${q9}, '1') or ${audit_c} < 4) as
the notes show based on these conditions, however the the last AND part is
not working as expected.
Hi, Bashir.
I think, there are missing parentheses.
Try this(hoping that will meet your need):
Note1
(selected(${q2}, '5') or ${q4} < 18 or selected(${q5}, '0') or ${c1} < 3 or
${audit_c} < 4) and
( (selected(${tp}, 'A') and selected(${q1}, '1')) ).
Note 2
${audit_c} < 3 )
and
( (selected(${tp}, 'A') and selected(${q1}, '2')) )
Note 3
${audit_c} > 3)
and
( (selected(${tp}, 'B') and selected(${q1}, '1')) )
Note 4
${audit_c} > 2 )
and
( (selected(${tp}, 'B') and selected(${q1}, '2')) )
Le mercredi 15 mars 2017 11:36:09 UTC+1, Bashir Jahed a écrit :
> Good Day,
> Note 1
> Note 2
> Note 3
> Note 4
> as example:
> - q2 = 5 or
> - q4 less than 18 or
> - q5 = 0 or
> - c1 less than 3 or
> - q7 = 1 or
> - q8 = 0 or
> - q9 = 1 or
> - audit_c leass than 4 AND
> - the user has selected a combination of tp = A and q1 = 2
> Thanks in advance for the great support and help.
> Bash
