I can`t pull data from my ODK briefcase. The forms are not showing up when
I want to data from the odk files.
On the settings tab there is "submission_url" and I have come to realized
that once I remove the "submission_url" in the settings tab I am then able
to pull data using ODK briefcase. I have data that I collected using the
other form which has "submission_url" in the settings tab and I want to
pull the data..... How do I pull data...please help
ODK Aggregate -down-to- ODK Briefcase (both definitions and submissions)
ODK Briefcase -to- ODK Aggregate (both definitions and submissions)
On Mon, Jul 13, 2015 at 2:20 PM, Rod wrote:
Dear Group,
My guess is that the forms that have submission_url are pointing to a
server that is different than you default server on ODK Collect. And so
when you pull using ODK Briefcase, you only get data from the default
server. Is that correct? Is your default server in ODK Collect different
from the server in the submission_url?
Need ODK services? http://nafundi.com provides form design, server setup,
professional support, and software development for ODK.
when I want to data from the odk files.
realized that once I remove the "submission_url" in the settings tab I am
then able to pull data using ODK briefcase. I have data that I collected
using the other form which has "submission_url" in the settings tab and I
want to pull the data..... How do I pull data...please help
