Help with ranking choices in a question and grid table
Hello everyone.
I have 2 quick questions.
Is it possible with odk and enketo to allow a respondent to rank the choices of a question?
Also what about asking them a question in grid table format. As in the image below
If yes do they work both in enketo and in ODK kollekt? because some interviews will be conducted via the app and some with enketo web form
Thank you in advance,
Riçard
I trust you know the rank feature, see https://docs.getodk.org/form-question-types/#rank-widget and https://xlsform.org/en/#rank.
Yes I tried it. It worked in ODK kollekt but I don't know why I wasn't able to rank in enketo.
what about grid table do you have any info? It worked on web form enketo but not in odk kollekt.
Hi @Ricard_Hoxha1
There are some known issues in Enketo related to the rank widget, such as this one, which might be the cause. As for the grid view, it is not really possible in the mobile app (ODK Collect). The only way to achieve something like that is Grid of selects on the same screen
