Dear Team,
Greetings,
I have been using ODK to develop data entry application but I have fail to
do the following things,
1: Is there a way to display a certain items in multiple selection question
depend on previous question?
The first question is "District Name"
2nd to display only division of the mention above district
2:after entering household member is there a way to display household member
names in a select question?
Regards,
Silas Temu
Silas,
The Open Data Kit website has a help section that explains many of
these questions. Especially the Form Design Section of the Help pages.
http://opendatakit.org/help/
http://opendatakit.org/help/form-design/
For the answer to your first question take a look at the Bindings page
http://opendatakit.org/help/form-design/binding/
The examples entitled 'Branching: Show this prompt if the answer to
/widget/int is less than 8'
and 'Branching: Show this prompt if the answer to /widget/branch (a
select1) is "n"' will help answer how to relevance (which is how you
Branching and Dependency type things).
Also you can check out these sample forms
http://code.google.com/p/opendatakit/source/browse?repo=forms
On Fri, Jun 15, 2012 at 9:08 AM, Silas Temu wrote:
> Dear Team,
> Greetings,
> The first question is “District Name”
> Regards,
> Silas Temu
