to display a name, for example, in a caption. use this in your label column
(assumes name variable has been collected/filled-in prior to asking):
What is ${name}'s job designation?
On Monday, June 18, 2012, silas temu wrote:
Dear Team,
Greetings,
I have been using ODK to develop data entry application but I have fail to
do the following things,
1: Is there a way to display a certain items in multiple selection
question depend on previous question?
The first question is “District Name”
2nd to display only division of the mention above district
2:after entering household member is there a way to display household
member names in a select question?
I've been looking on how to do this too. When I put ${variable} in the
label of a subsequent question I get an error though: Dependency cycle in
s; recursion limit exceeded!!
What am I doing wrong here?
Thanks for any help
Oliver
> column (assumes name variable has been collected/filled-in prior to asking):
>> Dear Team,
>> Greetings,
>> to do the following things,
>> Regards,
>> Silas Temu
Hi there, thank you for your help but what I want is to put those name as
items in selection list.. Is it possible?
From: opendatakit@googlegroups.com [mailto:opendatakit@googlegroups.com] On
Behalf Of ??.????
Sent: Monday, June 18, 2012 12:53 PM
To: opendatakit@googlegroups.com
Subject: Re: [ODK Community] Help
Dear Team,
Greetings,
1: Is there a way to display a certain items in multiple selection question
The first question is "District Name"
2:after entering household member is there a way to display household member
How are you using it? Inside repeats or groups? Try a simple test first.
Thanks for any help
Oliver
Dear Team,
Greetings,
Nevermind. I'm stupid, I didn't realize this was for xlsform. I figured out
how to do it in an xform.
On Monday, June 18, 2012 1:04:28 PM UTC+2, ニコノコ wrote:
> I'm sorry, I haven't encountered that error yet.
>> Hi,
>> Thanks for any help
>> Oliver
>>>> Dear Team,
>>>> Greetings,
>>>> Regards,
>>>> Silas Temu
>>>> Unsubscribe: opendatakit+unsubscribe@**googlegroups.com
>>>> Options: http://groups.google.com/**group/opendatakit?hl=en
"What is <output value = "/data/name />'s job designation?" is what I was
looking for.
Now I have another question can I somehow use this command in the label of
a select item?
On Monday, June 18, 2012 1:10:02 PM UTC+2, Tumaini Kilimba wrote:
> Are you guys literally using the code ${variable} or do you mean "What is
> Tumaini
>>> Hi,
>>> Thanks for any help
>>> Oliver
>>>>> Dear Team,
>>>>> Greetings,
>>>>> fail to do the following things,
>>>>> district
>>>>> Regards,
>>>>> Silas Temu
But I get an error message if I try to upolad or validate the xform.
My form looks like this:
Who is the boss?
1
Thanks for further help
On Monday, June 18, 2012 3:35:47 PM UTC+2, Tumaini Kilimba wrote:
> As Obama would say, Yes You Can...
> On Mon, Jun 18, 2012 at 3:50 PM, Oliver wrote:
>> "What is 's job designation?" is what I was
>> looking for.
>> of a select item?
>>> Tumaini
>>>>> Hi,
>>>>> Thanks for any help
>>>>> Oliver
>>>>>>> Dear Team,
>>>>>>> Greetings,
>>>>>>> district
>>>>>>> household member names in a select question?
>>>>>>> Regards,
>>>>>>> Silas Temu
>>>>>>> Unsubscribe: opendatakit+unsubscribe@**google**groups.com
>>>>>>> Options: http://groups.google.com/**group**/opendatakit?hl=en
"Nevermind. I'm stupid, I didn't realize this was for xlsform. I figured
out how to do it in an xform"
The formulas from xforms should work with xlsform, as xlsform just
generates the xform. If there is something that isn't working quite right
let us know and we will see what we can do to fix it.
Waylon
On Mon, Jun 18, 2012 at 8:49 AM, Pau Varela wrote:
not sure what output's 'value' attribute requires.. an itext works
perfectly fine:
what about the last slash you have in : value="/data/name /"/>
Otherwise, are you sure you can refer to a node via 'value'? does 'output'
accept ref?
first.
the label of a subsequent question I get an error though: Dependency cycle
in s; recursion limit exceeded!!
Thanks for any help
Oliver
label column (assumes name variable has been collected/filled-in prior to
asking):
Dear Team,
Greetings,
district
Tumaini
Thanks for any help
Oliver
Dear Team,
Greetings,
Thanks for any help
Oliver
Dear Team,
Greetings,
district
first.
Thanks for any help
Oliver
Dear Team,
Greetings,
district
No there is no problem, it was entirely my mistake I was trying to use the
xlsform (excel) syntax in my xform. When I did transform an xls into an
xform I did find the solution I was looking for.
On Monday, June 18, 2012 7:44:30 PM UTC+2, waylon wrote:
> To clarify
> Waylon
>> perfectly fine:
>> > value="jr:itext('t11o')"/>?
>> 'output' accept ref?
>> I hope it helps..
>> pau.
>> 2012/6/18 Oliver
>>> Who is the boss?
>>> 1
>>>> On Mon, Jun 18, 2012 at 3:50 PM, Oliver <hehf.heidelberg@googlemail.** com > wrote:
>>>>> was looking for.
>>>>> label of a select item?
>>>>>> Tumaini
>>>>>>> first.
>>>>>>>> Hi,
>>>>>>>> Thanks for any help
>>>>>>>> Oliver
>>>>>>>>> asking):
>>>>>>>>>> Dear Team,
>>>>>>>>>> Greetings,
>>>>>>>>>> have fail to do the following things,
>>>>>>>>>> selection question depend on previous question?
>>>>>>>>>> district
>>>>>>>>>> Regards,
>>>>>>>>>> Silas Temu
>>>>>>>>>> Unsubscribe: opendatakit+unsubscribe@**google****groups.com
>>>>>>>>>> Options: http://groups.google.com/**group****/opendatakit?hl=en
I do not really know what output requires, I am just trying around with ODK
to see if we could use it.
Having entries from previous questions appear as items in a select question
would be a neat thing, but it doesn't seem to be possible. At least not
with the output command.
Tumaini, you said it was possible, could you explain how you do it?
> perfectly fine:
> accept ref?
> I hope it helps..
> pau.
> 2012/6/18 Oliver
>> Who is the boss?
>> 1
>>>> was looking for.
>>>> of a select item?
>>>>> Tumaini
>>>>>> first.
>>>>>>> Hi,
>>>>>>> Thanks for any help
>>>>>>> Oliver
>>>>>>>> asking):
>>>>>>>>> Dear Team,
>>>>>>>>> Greetings,
>>>>>>>>> district
>>>>>>>>> Regards,
>>>>>>>>> Silas Temu
