getToken!: ADVERTENCIA: Could not open/create prefs root node
Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...)
returned error code 5.
getToken : ********************************************************
getToken : There is a new version of the SDK available.
getToken : -----------
getToken : Latest SDK:
getToken : Release: 1.9.48
getToken : Timestamp: Wed Oct 26 15:44:58 CDT 2016
getToken : API versions: [1.0]
getToken :
getToken : Your SDK:
getToken : Release: 1.9.42
getToken : Timestamp: Fri Jul 15 13:45:47 CDT 2016
getToken :
getToken : Please visit https://developers.google.com/appengine/downloads
for the latest SDK.
getToken!: Either the access code is invalid or the OAuth token is
revoked.Details: invalid_grant
getToken!: .
getToken!:
getToken :
status : Action failed or aborted by user
El martes, 6 de diciembre de 2016, 11:38:11 (UTC-6), José Manuel Mojica Velez escribió:
> Hello,
> Hello,
> In ODK Aggregate App Engine Updater, i am trying to get my code, but i
> have this mistake:
> Could not open/create prefs root node Software\JavaSoft\Prefs at root
> 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
> Can you please say me what can i do.
> Thanks,
It sounds like the access code is invalid or the OAuth token has been
revoked. In the ODK Aggregate App Engine Updater, try deleting the
token and getting another one.
On Tue, Dec 6, 2016 at 6:07 PM, José Manuel Mojica Velez wrote:
> This is what i get:
> getToken!: dic 06, 2016 12:03:50 PM java.util.prefs.WindowsPreferences
> getToken :
> getToken :
> for the latest SDK.
> getToken!: .
> getToken!:
> getToken :
>> Hello,
>> Hello,
>> have this mistake:
>> Thanks,
> "ODK Community" group.
If you have multiple gmail accounts, you may need to sign out of all of
them (e.g., from Gmail or another Google system, sign out). Then log into
JUST the account that owns the AppEngine project.
On Sat, Dec 10, 2016 at 11:14 AM, Yaw Anokwa wrote:
Hi José,
getToken :
getToken :
appengine/downloads
for the latest SDK.
getToken!: .
getToken!:
getToken :
Hello,
Hello,
have this mistake:
