Hi guys.
Is there a way that i can hide a set of question that i will populate their
answers using answers from other question, so that they wont appear on the
screen.
Hi guys.
screen.
thank you will try it
relevant="/data/q5= '1' and /data/q6 = '88'"
Skip logic allows you to show or hide questions depending on previous
answers. In the above example, the question will only show if the answer to
q5 is 1 AND q6 is 88, otherwise it remains hidden from the screen.
Nik
Hi guys.
their answers using answers from other question, so that they wont appear
on the screen.--
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
email to opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>.
