Hiding a default question
Hello,
Is there a way to make a question hidden on the phone?
I have a select one question with a default answer which i want hidden (and i will use these as hints later in the firm (so these can be quickly adapted for different languages/ locations, in the choice tab, and we wont have to edit the main survey). Any ideas?
thanks for your help!
Spike
I'm not sure I understand the question, Spike, but I'll give you a few options.
If you want to store a value in a form that the user does not see, use a calculate. You could also make the question not relevant based on some previous value. You can also make the question read only.
