Are these possible? I don't see anything about it on the examples page. Has
any thought been given to adding them? Or if they're possible, what is the
correct xml?
I like to keep option titles short for reporting purposes, but sometimes a
little extra explanation is needed.
Hey guys, never got a response on this one. Hints for select options? Yea
or nay?
Has any thought been given to adding them? Or if they're possible, what is
the correct xml?
Seems like a reasonable idea to me. I don't know if this XForms-y
enough, but I'd imagine it'd look like this...
branch prompt
This is the branch prompt
yes
Select this for yes
y
no
Select this for no
n
On Fri, Jan 11, 2013 at 5:10 AM, Thomas Smyth wrote:
> Hey guys, never got a response on this one. Hints for select options? Yea or
> nay?
>> the correct xml?
>> Thanks!
On Fri, Jan 11, 2013 at 9:21 AM, Thomas Smyth wrote:
> So I take it it's not currently possible...
>> branch prompt
>> yes
>> Select this for yes
>> y
>> no
>> Select this for no
>> n
>> > Yea or
>> > nay?
>> >> is
>> >> the correct xml?
>> >> sometimes a
>> >> Thanks!
