Hello All,
Please go through the job description & revert me with your updated
profile
Please revert me: sourav982.itscient@gmail.com
sourav982.itscient@gmail.com or laxman@itscient.com
laxman@itscient.com.
(NEED LOCALS)
ROLE: Security Admin
DURATION : 6 + Months
Job Description:
Responsibilities:
· Systems administration support for IBM Security Identity
Environment (ISIM / ISDI / ISDS).
· Installing, updating and configuring ISIM application adaptors.
· Development of policies, internal security, workflow and forms within
ISIM.
· Supporting project teams for integrations into the Honda
security environment.
· Investigate operational problems and develop counter measure
for remediation.
· Perform upgrades and apply patches to IBM Security software.
· Monitor the environment for effective operations.
MUSTS:
· IBM Security Identity Manager administration, design and support.
· IBM Security Directory Integrator - Including the ability write
complicated assembly lines from scratch and maintain an existing code base.
· Experience with IBM Security Directory Server - including the ability
to install from scratch, setup replication, manage issues and develop
complex
· queries and reports.
· Strong understanding of Identity Managements architecture concepts and
best practices.
· Strong technical skills with UNIX. - This means you need to be
comfortable with UNIX and can easily ssh into servers, use vi and other
common UNIX tools.
· Strong Javascript development skills - This means you should have
no problem writing custom operations in ISIM and maintaining an
existing javascript code base in ISIM
· Must have broad range of understanding with different technical
platforms (servers, networks, storage, etc.)
· Must be able to work individually as well as in a team.
· Self-starter, must be able to see projects and tasks from start
to completion.
· Must have strong written and verbal communications skills. You will
be required to work with project teams and end users in person, on the
phone and in writing.
WANTS:
· Experience with IBM Security Access Manager administration, design
and support.
· Experience with web application design and a strong understanding of
the HTTP protocol and reverse proxy systems.
· Experience with J2EE, C# or other language development
· Basic SQL and reporting skills - You should be able to write simple
SQL queries and work with reporting software to generate and manage
reports.
Position: Sr. Integration Architect/Developer
Duration: 6+ Months
Description
· Influence, design, and implement managed file transfer (MFT) solution
for
· Honda projects, and ensure its alignment with regional and global
· enterprise direction
Responsibilities
· Design global managed file transfer solutionReview the requirements
· Collaboratively work with integration, infrastructure, security, and
other counter-parts to design MFT solution
· Develop and implement global MFT solution Collaboratively work with
integration, infrastructure, security, and other counter-parts to develop
MFT solution
· * Perform all testing activities*
· Mentor technical resources in the project teams on MFT based solutions
· Assist with file transfer patterns, designing, and development using
MFT platform
· Provide technical support to the project teams
· Assist with troubleshooting of critical technical issues in
MFT platform.
*Musts:*
· Demonstrated integration experience using different file
transfer techniques, protocols, and products
· Experience in EDI solutions
· Java development experience
· Excellent written and verbal communication skills
· Experience in documenting the design
· Ability to develop and communicate technical concepts via:MS Word, MS
PowerPoint to non-technical people
· UML, code snippet, etc. to technical people
*Nice to have skills:*
· Experience in using Axway/Tumbleweed file transfer solutions
· Experience in using IBM/Sterling file transfer solutions
· Evaluating and/or implementing cloud based solutions (Amazon,
Google, Microsoft, Go Grid, etc.)
· Developing software for global and multi-language use
· Leveraging enterprise monitoring solutions to effectively monitor
the application
Soft Skills
· Ability to lead and work in a matrixed organization
· Ability to explain technical position without getting emotional
· Ability to work and deal with conflict (technical)
· Ability to communicate (upward, peer and downward) accurately and
at appropriate time
· Ability to manage and juggle multiple priorities with dexterity.
Thanks & Regards
Sourav Paul | Technical Recruiter
*IT–SCIENT LLC, Fremont, CA, USA *
*Email: *sourav982.itscient@gmail.com sourav982.itscient@gmail.com
Phone: 510-972-5265 <510-972-5265> | Fax: 877-701- <877-701-4872>5240
