I have captured a geoshape in my form and would like to display its area within the form. I am only familiar with ODK build for now so need a solution I can implement in ODK build. If it is not possible to show, is there a way to save this when submitting the form so the area is a field in aggregate?
I'm using ODK Collect and ODK Aggregate
I have put the area function in a format like this in the calculate field but keep getting zero as the answer. See my sample calculation. "area(/data/Farmdetails/farmarea)". am i referencing the data wrongly? strong text
Create a geoshape in ODK build and a numeric field, then try to set the value of the numeric or text object to the area of the geoshape so the user can see in odk collect?
I have a sample form i can share.
