Hi, i have a repeat of 500 values, and i want show a value in each interaction, after, when finish the repeat as a summary . I know that i can show a value to "repeat" when i use indexed-repeat(${item}, ${Rept}, 500) but this is for one to one.
I want know if there is a way for show an parameter without write the indexed-repeat() for each repeat.
thanks
Yes, you can use "join"
join(", ", ${item})
This should give a comma-separated list of all the filled-in item fields in
the repeat group.
The first term is the separator string, the second, and onward, are the
elements to concatenate.
thanks
thanks
I did not know you could do that
> join(", ", ${item})
> in the repeat group.
>> thanks
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
