@Grzesiek2010
@Xiphware
I have 2 types of questions, lets say...
Q1 - Single Selection (yes,no)
Q2 - Multiple Selection (op1, op2, op3, op4, op5)
if i select (yes in Q1) then (op1, op4 must be shown in Q2)
if i select (no in Q1) then (op2, op3, op5 must be shown in Q2)
i am using ODK Collect and ODK Aggregate
Hi @noman.s2325
there are two options to solve your problem:
- You can have two select_multiple question, the first one with options op1, op4 and the second one with options op2, op3, op5 and make only one of them relevant based on the first question: https://xlsform.org/en/#relevant
- You can also have just one select_multiple with all those options but use choice_filter to filter displayed options. It would be like https://docs.google.com/spreadsheets/d/1CCjRRHCyJXaSEBHPjMWrGotnORR4BI49PoON6qK01BE/edit#gid=1
Thank you @Grzesiek2010 for your wonderful support...
only 1 more question regarding your second suggestion is that i want to add another option in Q2 "Other", how could i add Other Option in Q2 for both of the option in Q1
i.e
Q2 - Multiple Selection (op1, op2, op3, op4, op5, other)
if i select (yes in Q1) then (op1, op4, other must be shown in Q2)
if i select (no in Q1) then (op2, op3, op5,other must be shown in Q2)
thanks in advance...
you can use or
in your filter like eg. cf=${state} or cf=’both’
csTest.xlsx (6.7 KB)
