How to avoid rewrite the same answers for differnet questions?
Dear team,
I would like to have your support to overcome a problem i´m facing. Please see below the issue:
I want to make the same question more than 5 times using select_multiple and the answers are the same for all question. So my problem is, I want to avoid rewriting the answers many times. I would like to know if there is a way to invoke a variable that contain the first choices answers in other answers?
**What ODK tool and version are you using?
I´m using a xlsform
Hello @fgmang,
You just have to write the select_multiple mases_a anywhere you want to access the "mases_a" choices. I am attaching a sample please have a look at it.
test_test.xlsx (9.3 KB)
Thanks and Regards,
SGSC.
Hi Dear,
Problem solved. Many thanks
Best Regards
