I am not sure, whether I put the subject correctly.
I am building a survey and it would take set of inputs depending upon
the Gender (Male/Female)
E.g;
Q1. Gender : Male / Female
If Male : Question no 2 to 5
If Female : Question No 6 to 10
Nayak
hi nayak,
you should take a look at the
https://bitbucket.org/javarosa/javarosa/wiki/buildxforms. you want to
focus on the skip logic sections to figure out how to do that. we're
working on an easier to use guide, but that's still a few weeks away.
you can also check out our sample household form survey at
http://code.google.com/p/opendatakit/source/browse?repo=forms. it has
some examples of skip logic there.
hope that helps,
yaw
> E.g;
> Thanks,
> Nayak
I found this to be helpful http://code.google.com/p/opendatakit/wiki/XFormLogicExplained
Hope that helps someone.
Matt
On Apr 14, 12:40 pm, Yaw Anokwa wrote:
> hi nayak,
> you should take a look at thehttps://bitbucket.org/javarosa/javarosa/wiki/buildxforms. you want to
> focus on theskiplogicsections to figure out how to do that. we're
> you can also check out our sample household form survey athttp://code.google.com/p/opendatakit/source/browse?repo=forms. it has
> some examples ofskiplogicthere.
> hope that helps,
> yaw
> > E.g;
> > Thanks,
> > Nayak
