Hi ODK Devs,
This should be fairly simple but i have no idea how to implement this in
ODK, i want to check if a user response (lets say from a range of 1 - 10)
is even or odd.
Regards,
Ayub
Hi ODK Devs,
is even or odd.
Regards,
Ayub
This question is more suitable for opendatakit@
opendatakit-developers@ is for people working on modifying the Java code,
not crafting forms.
This is a modulo function, represented as '%', which is a binary operator
for integer values. You should be able to do:
if(${fieldA} % 2 = 1, 'odd', 'even')
Modulo, e.g., A % 2 will equal the remain after A is divided by 2.
The set of possible remainders for A % 2 are 0 and 1. In this case, a
remainder of 0 means the value is even, a remainder of 1 means it is odd.
Hi ODK Devs,
is even or odd.Regards,
Ayub--
"ODK Developers" group.
Hi Mitch,
I should have posted the question in opendatakit@, will keep that in mind.
Here is what works:
relevant="(/data/number mod 2 = 1)"
relevant="if(/data/number mod 2 = 1, true(), false())"
This doesn't work: (% gives unknown operator error in validate)
relevant="if(/data/number % 2 = 1, true(), false())"
Regards,
Ayub
