Please can you help me to resolve this issue.
Please find attached an example.
I want to compare the "Total area" with "parcel area calc" without changing the order of questions!
if they are not equal we should not pass to the next step.
Any help? Thank you
Le jeudi 2 juin 2016 13:29:58 UTC+1, AMH a écrit :
> Hi All
> Any help? Thank you
> Med Helmi
This may be a limitation of the XLSForm converter.
The problem seems to be that the total_feld_calc field is stored as a
"string" field, so the subsequent sum(${total_field_calc}) will fail with a
type conversion failure.
If you hand-edit the XML file and change total_field_calc's data type to
"decimal", it should work.
(the data type is specified in the statement for the that field ).
Hi All
Any help? Thank you
I have a repeat group where I take Cultivated Area for each field and do
the Sum.
What I want to do is that the sum in repeat should be equal to the total
Area I had before the repeat group.
> See https://opendatakit.org/help/form-design/ for an explanation of the
> XML file structure.
> On Thu, Jun 2, 2016 at 8:31 AM, AMH <moh...@6grain.com > wrote:
>> Any help please? It's URGENT
>> Thanks
>>> Hi All
>>> Any help? Thank you
>>> Med Helmi
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
I have a repeat group where I take Cultivated Area for each field and do the
Sum.
Thank you!
Hi All
Any help? Thank you
