How to control and check number input in a household entry (Validation during capturing)
I want to control entry of a household size followed by different age groups of that household size. A series of validations to match the total household size with age groups
Total_Control (1).xlsx (12.1 KB)
Look at my code and advise
Adding constraints to control while capturing is on going
Hi @bkgwadi
Your requirements are not clear, please share your use case. Looking at your form my understanding is that you want the total number of males and females to match the totals for the various age groups. If my assumption is correct, a way of achieving what you want is to have 2 notes fields. First note field for the TotalPeople, then Second note field summing the values of the Age group fields.
The constraints in your current form, do not seem valid for what you want to achieve.
