# How to Disable Hibernate or Suspend on Virtual Machine?
**URL:** <https://forum.getodk.org/t/how-to-disable-hibernate-or-suspend-on-virtual-machine/12598>\
**Category:** Support\
**Tags:** odk-aggregate\
**Created:** [April 6, 2018, 3:33pm UTC](https://forum.getodk.org/t/how-to-disable-hibernate-or-suspend-on-virtual-machine/12598 "2018-04-06T15:33:02Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![nestor.lopez](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/nestor.lopez/32/3771_2.png) [@nestor.lopez](https://forum.getodk.org/u/nestor.lopez)\
**Post date:** [April 6, 2018, 3:33pm UTC](https://forum.getodk.org/t/how-to-disable-hibernate-or-suspend-on-virtual-machine/12598/1 "2018-04-06T15:33:02Z")
</div>
Hi
I just installed the virtual machine of ODK Aggregate 1.4 on a vSphere enviroment and suddenly the machine enter in a state of hibernation or suspend mode. The virtual machine shows a black screen and i have to move to mouse in order to enter in active mode.
Is there a way to disable this option an allow the Virtual Machine to run 24/7?
Best regards,
**Author:** ![yanokwa](https://getodk.b-cdn.net/user_avatar/forum.getodk.org/yanokwa/32/1695_2.png) [@yanokwa](https://forum.getodk.org/u/yanokwa)\
**Post date:** [April 6, 2018, 6:22pm UTC](https://forum.getodk.org/t/how-to-disable-hibernate-or-suspend-on-virtual-machine/12598/2 "2018-04-06T18:22:17Z")
</div>
Hi @nestor.lopez! The old VM is, well a bit old! Can you try the [ODK Aggregate v1.5](https://forum.getodk.org/t/odk-aggregate-v1-5/12493) VM? And see if that works better?
Also, when you get a chance, please [introduce yourself here](https://forum.getodk.org/t/-/6671). I'd also encourage you to add a real picture as your avatar because it helps build community!
