Hello, how to Encrypte odk data without ssl?
I've read this but I don't understand is
Encrypted forms must specify a submission_url
It means in your settings
sheet, you need a submission_url
header that points to your server's submission endpoint (e.g., https://example.appspot.com/submission). And if you follow the link in the docs, it'll take you to http://xlsform.org/#encrypted which also has a sample form.
Hello, Ok so it's compulsory to have a server? Could xxx.xxx.xxx.xxx:8080/OdkAggregatte be my url? meaning the one I use to get form in smartphone.
Thanks for your patience, @abdoul!
The specification says that a server URL is required, but I bet it would work without. Try both to confirm and report back so we can update the docs.
If you do need a server, the URL would be xxx.xxx.xxx.xxx:8080/OdkAggregate/submission
. You need the /submission
at the end.
