I have a finalized XML form from which the data needs to be exported in CSV
format.
Bindu
format.
Bindu
have you reviewed the usage part of the ODK website?
http://opendatakit.org/use/briefcase/
you need to pull the xml into briefcase then you can export.
cheers
dan
Oh cool..I will surely try it out..
Yes Dan.
Using Briefcase for exporting data is not clear enough in the ODK website.
Thats my question..how to pull the XML file to briefcase? I have the XML
file as a local copy (there is no ODK Aggregate in the picture).
I need help on how to use Briefcase and export data from local copy of XML
file.
Bindu
ok so this is how I do it.
sorry that's from memory so some of the clicks and names of sections may be
a little bit wrong but that should be enough to get you up and running.
thanks
dan
Yes Dan.
file as a local copy (there is no ODK Aggregate in the picture).I need help on how to use Briefcase and export data from local copy of XML
file.Thanks,
BinduOn Thursday, February 28, 2013 8:36:14 PM UTC+5:30, Daniel Probert wrote:
http://opendatakit.org/use/**briefcase/http://opendatakit.org/use/briefcase/
cheers
CSV format.Thanks,
Bindu--
Daniel Probert
Head of IT Innovation
Camfed International
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
Tel: +44 (0)1223 362648
DD: +44 (0)1223 221059
Fax: +44 (0)1223 366859
Email: dprobert@camfed.org
Camfed International is a company limited by guarantee registered in
England and Wales. Registered offices: St Giles Court,24 Castle Street,
Cambridge, CB3 0AJ, UK. Company No. 2874653. UK registered charity No.
1029161.
Dan,
I can execute until step 5. When I browse to the location of the XML file
on the local drive, I am getting the attached error.
Thanks for all your help Dan.
Bindu
Hi Bindu,
You actually need a copy of your forms and instances folder not just the
xml file.
If you still have your device that the forms was completed.
If you connect the device to your computer then browse the device you will
see a folder ODK - open that and make sure you copy of forms and instances
to your computer - then point brief case to the folder they are in.
i had a similar problem when I first started out with briefcase then found
out you have to point briefcase at the entire folder
cheers
dan
Dan,
on the local drive, I am getting the attached error.Thanks for all your help Dan.
Bindu
- i copy the odk folder from my rebooted android device to a location on
my computer
2.i open briefcase
3.i make sure i'm on the pull tab- i then click on the drop down and make sure I select pull data from
and select custom location(last option)- then click on connect or browse - and go to the location you copied
the odk folder to- i then press pull - this will then show me a list of forms that are on
my device- you can then go to the export tab and select the forms you want to
export as csvsorry that's from memory so some of the clicks and names of sections may
be a little bit wrong but that should be enough to get you up and running.thanks
danOn 28 February 2013 15:30, Bindu Susheel jayara...@gmail.com wrote:
Yes Dan.
website.Thats my question..how to pull the XML file to briefcase? I have the
XML file as a local copy (there is no ODK Aggregate in the picture).I need help on how to use Briefcase and export data from local copy of
XML file.Thanks,
http://opendatakit.org/use/**bri**efcase/http://opendatakit.org/use/briefcase/
cheers
in CSV format.Thanks,
Bindu--
Unsubscribe: opendatakit...@**googlegroups.com
Groups "ODK Community" group.
an email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
Email: dpro...@camfed.org
1029161.--
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
1029161.
yoohoo..It worked!
Dan, thanks so much for your guidance...I could not find any documentation
about this anywhere!
It had kept me hanging since yesterday!!!
No worries glad to be of use. I may actually contribute a user manual to
the community for briefcase..
yoohoo..It worked!
about this anywhere!It had kept me hanging since yesterday!!!
On Thursday, February 28, 2013 11:03:49 PM UTC+5:30, Daniel Probert wrote:
Hi Bindu,
xml file.If you still have your device that the forms was completed.
will see a folder ODK - open that and make sure you copy of forms and
instances to your computer - then point brief case to the folder they are
in.i had a similar problem when I first started out with briefcase then
found out you have to point briefcase at the entire foldercheers
danOn 28 February 2013 17:30, Bindu Susheel jayara...@gmail.com wrote:
Dan,
file on the local drive, I am getting the attached error.Thanks for all your help Dan.
Bindu
on my computer
2.i open briefcase
on my device- you can then go to the export tab and select the forms you want to
may be a little bit wrong but that should be enough to get you up and
running.thanks
Yes Dan.
XML file.Thanks,
http://opendatakit.org/use/**bri****efcase/http://opendatakit.org/use/briefcase/
cheers
Bindu--
Unsubscribe: opendatakit...@**googlegroups.**com
Options: http://groups.google.com/**group**/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en
an email to opendatakit...@**googlegroups.**com.
For more options, visit https://groups.google.com/**grou**ps/opt_outhttps://groups.google.com/groups/opt_out
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
1029161.--
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
1029161.--
Daniel:
that would be very thoughtful and generous of you. I hope that you do.
Thanks in advance,
Gaetano
On 28 Feb 2013 18:13, "Bindu Susheel" jayaram.bindu@gmail.com wrote:yoohoo..It worked!
documentation about this anywhere!It had kept me hanging since yesterday!!!
Hi Bindu,
Dan,
Bindu
on my computer
2.i open briefcase
running.thanks
Yes Dan.
of XML file.Thanks,
cheers
exported in CSV format.Thanks,
Bindu--
send an email to opendatakit...@**googlegroups.**com.
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
1029161.--
Daniel Probert
St Giles Court
24 Castle Street
Cambridge
CB3 0AJ, UK
1029161.--
There's another way that I use, which I personally find simpler, but do
whatever you're most comfortable with.
Looks like a lot of steps, but I just break it down so it's easier to
follow if you're new to it.
Please let me know if this isn't clear,
Sam
