Hi, i'm trying to create a survey form in which i need to collect the name of the households and ask series of questions about them under different headings. But I am having problem when filling the form on phone due to some questions which is relevant for female only, which i have to link to a question previously asked under the first repeat group. please how can i solve this problem.nassco_script.xlsx (51.8 KB). please help check question E6a and E6b under "relevance" in the above uploaded form. i do not know what to put there. please help
Hi @matolab
I think you are referring to variables C6a and C6b.
I suggest you proceed in a similar way to the name3 variable:
- create a new calculated field with the gender of the household member
- you use this new variable in the relevant condition.
Btw, I think you want to correct the label of var C6 from (NAME) to ${name3}
I hope this helps!
Andrea
Hi @matolab,
Thanks for your feedback. Please close the issue by marking the solution if you are satisfied with the answer.
