I would like to refer to an answer (but the LABEL not the NAME of this
answer) from a previous question in a later question.
I am using XLS to write out my survey.
E.g. For the below question, if the answer to the first question is "bread"
I would like the second question to read on the phone as "Did the household
have bread available all year long?" But right now it is showing up as
"Did the household have 1 available all year long?"
"survey" tab type name label
select_one staple staple1 What is the
household's main staple food?
select_one yesno staple_yesno Did the household have
${staple1} available all year long?
"choices" tab type name label
staple 1 bread
staple 2 rice
The selected 'value' is concatenated with a prefix string to construct an
itext entry that holds the label for that value; the string is then
retrieved via a jr:itext() call (which can be used within calculate
expressions).
"bread" I would like the second question to read on the phone as "Did the
household have bread available all year long?" But right now it is
showing up as "Did the household have 1 available all year long?"
staple 1 bread
staple 2 rice
