How can i restore saved and send forms locally in Andorid Device (ODK Collect)
If you removed those forms manually or Delete after send
option is enabled in General Settings -> Form management
, there is no way to restore them, otherwise they are still in odk
directory and you can send them again from Send Finalized Form ->
⋮ -> Change View -> Show Sent and Unsent Forms
