How to send data from odk collect to odk aggregate
i'm having problem to submit filled up form from odk collect to tomcat
server(odk aggregate)..i'm not having any idea how to connect to a local
server i.e tomcat server(odk aggregate)..so if there is anyone with the
answer or solution..that would be great...thanks
See https://opendatakit.org/use/aggregate/tomcat-install/
Sounds like you have a network configuration problem.
Thanks, Mitch for your reply.
··· On Monday, January 12, 2015 at 11:46:20 AM UTC+5:45, santosh sangachhen wrote: > > i'm having problem to submit filled up form from odk collect to tomcat > server(odk aggregate)..i'm not having any idea how to connect to a local > server i.e tomcat server(odk aggregate)..so if there is anyone with the > answer or solution..that would be great...thanks > >
