I have installed ODK Aggregate in local server, running everything is ok, then I want to using my mobile ODK Collect to download form and submit data. in ODK COLLECT i open the setting menue, and open "Configure platform settings",how can I seting the "URL" AND User name and password.
server platform I selected ODK Aggregate. if I select other platform, How can I known the ODK web formlist address?
When I view my form list ,the address is like below:
http://myserver:8080/ODKAggregate/Aggregate.html#management/forms///
but I can't find the address of real list in xml.
You should go with below link might be this will helpful for you.
http://docs.opendatakit.org/aggregate-install/#installing-on-tomcat-local-or-cloud
one question from my side is: Did you chnage settings on server on the ODK Collect in your android phone.
Narendra
I’m not sure I understand your question. If you have ODK Aggregate, why are you selecting other as a platform type?
when I selecting other platform ,the setting option will changed ,you can freely change you access list path and submission path.becaus the default path is : /formList. I just want to know, the ODK aggregate default path is what?
thank you reply but the link not using for this question.
I want change setting on server, but on ODK Aggregate web ,I can't found the place where I can setting the path of formList.
remind: In my mind, the dawnload form address just must be like belowing:
http://myserver:8080/ODKAggregate/myaccount/formList
Aggregate's form list is going to be at http://myserver:8080/ODKAggregate/formList and the submission list is going to at http://myserver:8080/ODKAggregate/submission. There is no easy way to change these paths in the Aggregate UI.
