The logcat file will generally only be useful to a developer. If an error
occurs, it will show the point at which the error occurs, with respect to
the source code of the application.
ODK Validate is more appropriate for reporting the location within a form
definition that has an error.
Interestingly, I am unable to open this zip file. It reports an unknown
compression format error.
Are you running the latest ODK Collect 1.1.7 ? Or 1.2 ? We fixed several
type conversion errors with the latest versions of these.
On Fri, Jul 13, 2012 at 1:11 AM, ゴー・ニコライ wrote:
I'm getting this error on ODK Collect when I open a particular form I
made: Error occurred: java.lang.Double.
I've run catlog to capture a log file. How do I use the log file to track
the problem? Or is it only useful for developers?
