Hi everyone,
I want to add index-repeat within the repeating group.How can I do? ,see the form bellow and the group name is Member_information
chila.xls (116 KB)
householdlist.csv (70.9 KB)
Hi @godlove
your form is quite big and it's not clear how you can use indexed-repat there so I'll just attach a sample form which uses it and I hope it will help:
choice_name_and_indexed-repeat.xls (7.5 KB)
Hi @Grzesiek2010
I have already got a solution and thank you for your support.
That's great you were able to find out a solution on your own. Please remember to at least add a comment next time because someone might spend much time trying to help you when you don't need that help in fact.
Sure bro..next-time I will do that.
Hi guys
I need a help please, I have already insert search function in my xls form but could not showing a text field which will help me to find the only one number which I want, it shows the lists number only. How can I do.Lab.xls (29.5 KB)
Memberlist.csv (352 Bytes)
