It is impossible to answer this, as I have no idea what line 1066 column 1
is.
If you are hand-coding your XML , this is likely a special character of
some sort (e.g., weird space character, something that looks like the
standard < but isn't, etc.).
You should use XLSForm or Build for form generation. Working directly with
XML is too error prone.
On Wed, Sep 11, 2013 at 1:04 PM, wrote:
I am trying to write skip logic for an XML form that will be uploaded as
an electronic questionnaire on a mobile device.
Currently the XML I have isn't able to be uploaded to the ODK server and I
get the following error message:
" Error: Problem with JavaRosa Parsing Form:
org.javarosa.xform.parse.XFormParseException: XML Syntax Error at Line:
1066, Column: 1!"
This is our code- does anyone know if we are tagging incorrectly?
Thank you for your response. I've used a validation tool and our XML is valid; however, I am still unable to upload to ODK. The form is 44KB, so size shouldn't be an issue. I receive the Google App Engine error message (copied here). I've looked through our logs etc and we are not over quota. Do you have any suggestions?
