Works for me on Android 4.0.2, and I'm pretty sure it works on other
versions of Android. Also tried '™' which is the trademark
lettering.
On Wed, Feb 15, 2012 at 05:59, Matteo Sisti Sette wrote:
> Hi,
> Html entities within texts in forms are not decoded in ODK Collect. Or at
> least not numeric entities such as 见 (chinese characters).
> They are shown literally (ampersand hash numbers semicolon).
> Is this the expected behaviour??? Shouldn't html entities be decoded??
> thanks
> m.
Is it possible that this has been fixed after Collect 1.1.7?
I'm using 1.1.7 because I've "hacked" it a little bit (when that was
the latest version) and I still haven't learned how to generate a
patch of my changes and apply it to a newer version.
2012/2/16 Yaw Anokwa :
> Matteo,
> lettering.
> Yaw
>> Hi,
>> thanks
>> m.
Probably not. We've supported XML entities for a long time.
>> Matteo,
>> lettering.
>> Yaw
>>> Hi,
>>> thanks
>>> m.
> Matteo Sisti Sette
> matteosistisette@gmail.com
> http://www.matteosistisette.com
I'm actually serving the form the wrong way (encoding html entities twice)!!
:x :#
2012/2/16 matteo sisti sette :
>> Matteo,
>> lettering.
>> Yaw
>>> Hi,
>>> thanks
>>> m.
> Matteo Sisti Sette
