Hi All
I have a few agents collecting data and have noticed that some of the images
are not being uploaded. Is there anything that can be causing this and is it
possible to retrieve these images from the devices.
Bash
Hi All
Bash
See this thread:
https://groups.google.com/forum/#!topic/opendatakit-developers/sfb26DRIyK0
If the transmission failure is while in the field, you might have better
luck sending the files via WiFi in your location.
Or, you can manually upload the missing attachment via the Form Management
/ Submission Admin tab -- the "Manually Upload Submission Data" button.
In the worst case, you can send the form, and the problematic attachment
via e-mail to a central location with better internet connectivity where
someone can use that manual upload button to upload the attachment. You
only need to send the problematic attachment(s) and the submission file --
once the attachment is uploaded, the submission should disappear from the
Form Management / Submission Admin tab for that form and appear in the
Submissions tab for that form (it displays in the Submission Admin tab
until all its attachments are present, then is marked as completed, and
moved to the Submissions tab, where no further modifications are allowed).
Hi All
images are not being uploaded. Is there anything that can be causing this
and is it possible to retrieve these images from the devices.Bash
<http://www.avast.com/>
This email is free from viruses and malware because avast! Antivirus
http://www.avast.com/ protection is active.--
Thanks for this. Seeing my agents are still in the field and not very bright can you tell me is the photos will still be on the device event after the respective form has been finalised and sent?
See this thread: https://groups.google.com/forum/#!topic/opendatakit-developers/sfb26DRIyK0
If the transmission failure is while in the field, you might have better luck sending the files via WiFi in your location.
Or, you can manually upload the missing attachment via the Form Management / Submission Admin tab -- the "Manually Upload Submission Data" button.
In the worst case, you can send the form, and the problematic attachment via e-mail to a central location with better internet connectivity where someone can use that manual upload button to upload the attachment. You only need to send the problematic attachment(s) and the submission file -- once the attachment is uploaded, the submission should disappear from the Form Management / Submission Admin tab for that form and appear in the Submissions tab for that form (it displays in the Submission Admin tab until all its attachments are present, then is marked as completed, and moved to the Submissions tab, where no further modifications are allowed).
On Wed, Jul 2, 2014 at 6:23 AM, Bashir Jahed bashir@radarmob.com wrote:
Hi All
I have a few agents collecting data and have noticed that some of the images are not being uploaded. Is there anything that can be causing this and is it possible to retrieve these images from the devices.
Bash
This email is free from viruses and malware because avast! Antivirus http://www.avast.com/ protection is active.
Unsubscribe: opendatakit+unsubscribe@googlegroups.com mailto:opendatakit%2Bunsubscribe@googlegroups.com
This email is free from viruses and malware because avast! Antivirus protection is active.
Bashir,
Your agents are probably plenty bright.
All data (forms, multimedia, sent or unsent) is stored on the device unless
explicitly deleted by the user in the Delete Saved Form interface.
after the respective form has been finalised and sent?Thanks
From: opendatakit@googlegroups.com [mailto:opendatakit@googlegroups.com]
*On Behalf Of *Mitch Sundt
Sent: 02 July 2014 06:43 PM
To: ODK Community
Subject: Re: [ODK Community] images not uploadingSee this thread:
https://groups.google.com/forum/#!topic/opendatakit-developers/sfb26DRIyK0If the transmission failure is while in the field, you might have better
luck sending the files via WiFi in your location.Or, you can manually upload the missing attachment via the Form Management
/ Submission Admin tab -- the "Manually Upload Submission Data" button.In the worst case, you can send the form, and the problematic attachment
moved to the Submissions tab, where no further modifications are allowed).On Wed, Jul 2, 2014 at 6:23 AM, Bashir Jahed bashir@radarmob.com wrote:
Hi All
mitchellsundt@gmail.com--
Options: http://groups..google.com/group/opendatakit?hl=en
http://groups.google.com/group/opendatakit?hl=en
