I want to know how to implement multiple_select and choice filter using external itemsets.csv file.
By using external itemsets.csv file select multiple type question is changing to select_one type question. Choice filter is working but both choice filter and select_multiple is not working when multiple choices are fetching from external itemsets.
Hi @rakesh0143, are you able to post the questions and files you're trying to get to work? Having those to work with would help people trying to understand the issue.
You have the variety choices list on both the choices worksheet of your xlsx file and in your itemset.csv file. At only 86 rows, I don't think you would need to have it in an external itemset, just in the form itself.
I uploaded just the xlsx file to KoBo and both the choice_filter and select_mulitple within the repeat group worked in the web preview of the form powered by Enketo.
