Implementing an ODK project
Dear Sir/Madam,
My names are Sitwala here in Zambia. I would like to implement a phone based data collection system. I don't have an android enable phone to launch ODK collect yet but wanted to use the emulator. Could should give me the steps to install the emulator.
Sitwala Wamunyima
FQM
Zambia
Sitwala,
The Android emulator is miserable. Try using GenyMotion at
http://www.genymotion.com instead.
On Tue, Aug 12, 2014 at 7:18 AM, Sitwala Wamunyima Sitwala.Wamunyima@fqml.com wrote:
Dear Sir/Madam,
data collection system. I don’t have an android enable phone to launch ODK
Sitwala Wamunyima
FQM
Zambia
Hi Sitwala, the emulator included in the ADT can have performance problems if you do not have a powerful machine and also you can face some problems because it is not providing all the tools you could need. In any case, if you do not have access to android device you could follow the instructions in developer.android.com to learn how to set up the virtual device. If you are using Eclipse ADT go to Android Virtual Device Manager and there create a new device, you should select the options according to your project target. If you are working with a windows machine take into that the emulator is facing some issues with the RAM so try to be conservative. I hope this help
··· El martes, 12 de agosto de 2014 16:28:06 UTC+2, Sitwala Wamunyima escribió: > Dear Sir/Madam, > > > > My names are Sitwala here in Zambia. I would like to implement a phone based data collection system. I don’t have an android enable phone to launch ODK collect yet but wanted to use the emulator. Could should give me the steps to install > the emulator. > > > > Sitwala Wamunyima > > FQM > > Zambia
