Once we send the finalized forms to the server and checked the downloaded data, if there are any errors or unfilled fields, can we import those responses to the tablets and enter data or correct it in the field.
I have tried using push option through briefcase, but through this we can import data to the server. Right?
Hi, I don't think that is possible. However, you can import data/export data using briefcase.
Hi @Aline_Kullu,
From the device end, once data is finalized and submitted it is done. No more edits can be performed. If it is really important to correct this using the device, then those data have to be collected afresh. Then submitted. Be sure to have unique identifier which will enable you to identify each record uniquely. Hence identify any associated duplicated.
