I have ran into trouble using ODKMETA to import my repeat groups into
STATA. Execution runs up-to the first repeat group where the DO file seems
to assign a prefix "SET-OF-..." to the repeat group name, and the resulting
name throws a variable not found error.I am using formhub. I will
appreciate anyone who can point me in the right direction. I have written
privately to the ODKMETA guys, in the hope of finding a away out.
I have just run into the same problem. Has it been solved?
Thanks so much,
Chris
Am Mittwoch, 27. August 2014 13:22:45 UTC+5:30 schrieb luq...@gmail.com:
> Dear All,
> I have ran into trouble using ODKMETA to import my repeat groups into STATA. Execution runs up-to the first repeat group where the DO file seems to assign a prefix "SET-OF-..." to the repeat group name, and the resulting name throws a variable not found error.I am using formhub. I will appreciate anyone who can point me in the right direction. I have written privately to the ODKMETA guys, in the hope of finding a away out.
> Regards,
> Luka
