hi, kindly help on how to go about this. i have income data which are all integers. so i have programmed odk to sum all at the end. After there is also expenditure which odk automatically sums up (calculate....note scenario).
Now my problem is that i want odk to be able to restrain the user so that any figure (value) generated must not exceed income.
eg.
total income = 1000
total expenditure = 2000
in this case expenditure should not exceed expenditure.
On the screen that shows the final number, add a constraint that
${total_expenditure} <= ${total_income}. Then add a constraint_message
for them to go back and check the numbers.
> eg.
> total income = 1000
> Kindly help on how to go about it
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
I'm displaying it with a note type variable in the end. So I should add
this constraint in the note type row ?
On Friday, 25 November 2016 11:44:12 UTC+5:30, Yaw Anokwa wrote:
> Hi there,
> Yaw
> scenario).
> > eg.
> > total income = 1000
> an email to opendatakit...@googlegroups.com .
If I am not mistaken that should work. I will double check this when I
return to my PC.
Hi there,
scenario).
eg.
total income = 1000
"Like a camera I use the negative to develop..uDig"
"Success is the ability to go from one failure to another with no loss of
enthusiasm"
----------------------------------------------------------------------------------------------------------> OutSourceRox Roxroy K. Bollers
GIS & IT Service Provider
tel. 592.685.2737 ......................................................... Follow Us On Facebook
Google+
Twitter: @drbollers
> return to my PC.
>>> Hi there,
>>> Yaw
>>> > scenario).
>>> > eg.
>>> > total income = 1000
>>> > an email to opendatakit...@googlegroups.com.
> enthusiasm"
> OutSourceRox
> Roxroy K. Bollers
> tel. 592.685.2737
> Follow Us On
> Facebook
> Google+
> Twitter: @drbollers
On Saturday, 26 November 2016 12:04:31 UTC+5:30, Yaw Anokwa wrote:
> Varun,
> It should work. Try it and report back.
> Yaw
> On Fri, Nov 25, 2016 at 5:07 PM, Roxroy Bollers <rkbo...@gmail.com > wrote:
> > return to my PC.
> >>> Hi there,
> >>> Yaw
> are
> there is
> >>> > scenario).
> >>> > eg.
> >>> > total income = 1000
> send
> Groups
> an
> of
> > enthusiasm"
> > OutSourceRox
> > Roxroy K. Bollers
> > tel. 592.685.2737
> > Follow Us On
> > Facebook
> > Google+
> > Twitter: @drbollers
> Groups
> an
