Dear All,
I am working on a project in household survey currently and tried the suggested working syntax "indexed-repeat(${name}, ${repeat}, if(${id} != null, ${id}, 1))" to call data entered in previous repeat group. However i got the problem "Sorry, ODK has stopped". No hint given on where is the problem. could you help me out? see the attached. i am using ODK Collect 1.4 (1038) on SAMSUNG Galaxy tab3.
Another question is how to generate a set of non-duplicated random numbers from a set of pre-entered sequential numbers, i.e., the numbers of households. I have the program as attached but some of random numbers are duplicate.
Thanks in advance.
Zaixing
indexed_repeating4.xlsx (14.4 KB)
random23HHselection2.xlsx (14.1 KB)
Hi Zaixing,
Does the form validate with ODK Validate
(http://opendatakit.org/downloads/download-category/validate/)? If you
haven't validated the form, try that first.
Next, upgrade to ODK Collect 1.4.3
(http://opendatakit.org/downloads/download-category/collect or Play
Store). It has lots of bug fixes.
Finally, if the problem still happens, get a stack trace by following
the steps at https://code.google.com/p/opendatakit/wiki/CollectTroubleshooting
and file a bug report at
https://code.google.com/p/opendatakit/issues/list. I find using the
Android SDK is the best way to get traces.
As far as non-duplicated random numbers, I don't think there is an
easy way to do this. I would recommend you generate the household
selection distribution before hand and load it in as baseline data
using http://opendatakit.org/help/form-design/data-preloading/.
On Sun, May 11, 2014 at 1:09 AM, zhangzaixing2014@gmail.com wrote:
Dear All,
Thanks in advance.
Zaixing
Hi Zaixing,
Dear All,
Thanks in advance.
Zaixing
Dear Yaw,
thanks so much for your suggestion in using the Validate. it helped me find the bugs with the first problem and it is Ok now.
Will try do work on the second one.
All the best
Zaixing
On Monday, May 12, 2014 1:03:12 PM UTC+11, Yaw Anokwa wrote:
> On Sun, May 11, 2014 at 1:09 AM, wrote:
