Dear Sir,
i have a problem, that in a open repeat i want to make a check list. that which option was selected and which one was not.TEST.xls (183 KB)
Can you provide more details about how you want your form to work?
You want them to select one or more options from a list, and then answer yes no for each option that was selected? You might be able to use a combination of select_multiple
and relevant
