Inflated image size - quality/compression
Ok great! So when 5004 is fixed it will address the large files when max-pixels is used (will you hard code quality or will it be an option/form setting?), but for the meantime the best option appears to be to remove max-pixels to prevent larger file sizes when they're not annotated
Tangent - is there any way to process all the existing images server side to ~75% quality (using Central as SaaS from getodk) to reduce space and speed transfer?
Hi @ahblake
in v2022.1.1 we added a fix for this issue (https://github.com/getodk/collect/issues/4978).
Now if you scale images down they should really have smaller size. Have you maybe tested it?
I will test this very soon, thanks!
Edit:
@Grzesiek2010, I tested on a samsung galaxy S10 running Collect 2022.1.1:
  1. Capture image, no max-pixels: 3856kb
  2. Choose image, no max-pixels: 3931kb
  3. Capture image, max-pixels=4000: 1835kb
  4. Capture image, max-pixels=4000: 1868kb
    Phone reports 'choose image' source as 3.84mb
Resaving (1) at 75% quality: 1609kb
Resaving (3) at 75% quality: 1700kb
Resaving (3) at 80% quality: 1841kb
So, as far as I can see:
  • Not using max-pixels will deliver the device camera output or selected image untouched
  • Using max-pixels=xxxx will return an image at approx 80% jpg quality
  • Ffor devices that don't allow setting camera quality, I should at a minimum use max-pixels=sensor resolution, or a lower value.
Going from ~6-8mb to ~1-2mb is fantastic, thanks for the fix!
Thanks a lot for reporting the issue with all those details. The bug existed for a long time but we weren't aware of it at all.
