Hi people,
it is possible to introduce an automatic numbering continues in a specific
question at XForms ?
thanks
Hi people,
thanks
hi renan,
what do you mean by automatic numbering continues? maybe you can give
us an example of what two or three of those prompts would look like?
yaw
Thanks Yaw... for your attention!!!!
we are conducting a forest inventory, and we have a numbering remains of
individuals sampled (ie: a tree, tree 2, tree 3, tree ... 500)
such as auto-increment: the first instance (tree number 1) already receive a
numbered and can* be see in *cell phone interface, so the next instance
would automatically continue (previous numbering +1) = 2.
is possible to enable see this numbering automatically for every instance?
this is helpful to eliminate 1 question for Xforms and allow easier the
field collect!!!
Renan
hi renan,
us an example of what two or three of those prompts would look like?yaw
On Mon, Feb 7, 2011 at 07:21, Renan Kamimura renankami@gmail.com wrote:
Hi people,
thanks--
Renan A. Kamimura--
Renan A. Kamimura
I have/had a similar need and simply infer it from 'start' time stamps so
don't even need it on the form. Maybe that approach would work for you.
-steve-
individuals sampled (ie: a tree, tree 2, tree 3, tree ... 500)such as auto-increment: the first instance (tree number 1) already receive
a numbered and can* be see in *cell phone interface, so the next
instance would automatically continue (previous numbering +1) = 2.is possible to enable see this numbering automatically for every instance?
field collect!!!Thanks,
Renan
2011/2/7 Yaw Anokwa yanokwa@gmail.com
hi renan,
Hi people,
thanks--
Renan A. Kamimura--
Renan A. Kamimura--
currently, there is no easy way to increment across different
instances (or form filling sessions).
Ok guys!! thanks a lot!!
now, i have other doubt ... you guys have some script that can demonstrate
how LOGICS SKIP "range" ; "is equal than" ; "is less than" and " is greater
than" ...
Renan
instances (or form filling sessions).On Mon, Feb 7, 2011 at 10:31, Steve Roberts steve@roberts.org wrote:
so
-steve-On Mon, Feb 7, 2011 at 10:19 AM, Renan Kamimura renankami@gmail.com wrote:
have a numbering remains ofindividuals sampled (ie: a tree, tree 2, tree 3, tree ... 500)
- already receive a numbered and can be see in cell phone
interface, so the next instance would automatically continue (previous
numbering +1) = 2.
instance?this is helpful to eliminate 1 question for Xforms and allow easier the
field collect!!!
Renan2011/2/7 Yaw Anokwa yanokwa@gmail.com
hi renan,
Hi people,
thanks--
Renan A. Kamimura--
Renan A. Kamimura--
Renan A. Kamimura
the widgets and eimci forms are good places to start. see
http://code.google.com/p/opendatakit/source/browse?repo=forms
for example, if you want prompt_b to be relevant when prompt_a is
greater than 6, you'd do something like
the trick is that < > don't work since the forms are in xml. you need
to use the url safe versions (< > <=; >=;)
