Installing an App Engine Instance
I am following http://opendatakit.org/use/aggregate/ instruction to install
an App Engine Instance. At step #3 "Download ODK Aggregate vN.N.Nhttp://code.google.com/p/opendatakit/downloads/list,
unzip and run it...", can someone tell me how to run it. I opened
"ODKAggregateDeploy0.9.8.1" folder and don't know what to do. Thanks,
Wen
These instructions are for 1.x I'll update the vN.N.N to v1.N.N.
install an App Engine Instance. At step #3 "Download ODK Aggregate
vN.N.N
http://code.google.com/p/opendatakit/downloads/list, unzip and
Wen
Thanks to both Mitch and Chan. I had installed it successfully.
vN.N.N
Wen
...updated -- download the ODK Aggregate v1.2.0 file appropriate for your
operating system, and then these instructions will make more sense:
v1.N.Nhttp://code.google.com/p/opendatakit/downloads/list.
Select the latest Featured release for your operating system. These
downloads are wizard-based installers for the various operating systems. If
you are running OSX, you must unzip the downloaded file before running the
installer within it. Consider using a non-Featured release during forms
development (to help us identify issues prior to our production release).
vN.N.N
Wen
Thanks Mitch, I had uploaded the configured ODK appregate to APp Engine.
I am now at the 'Using the Application' on
http://opendatakit.org/use/aggregate/.
For " you need to create an ODK username and password and grant it Data
Collector
privileges. Do this on the Site Admin / Permissions tab",
where do I find the Site Admin/Permissions tab?
Wen
Download ODK Aggregate v1.N.Nhttp://code.google.com/p/opendatakit/downloads/list.
vN.N.N
Wen
Log onto your ODK Aggregate instance using the Google e-mail address that
you specified during the install. There will be a "Site Admin" tab with a
"Permissions" section.
Collector
Wen
I am following http://opendatakit.org/use/**aggregate/http://opendatakit.org/use/aggregate/ instruction
to install an App Engine Instance. At step #3 "Download ODK
Aggregate vN.N.N
Wen
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
Hi Wen,
This is the manual that lead me to successfully install GAE. Hope it might
help you.
How to create app engine instance.pdf (495 KB)
··· On Wednesday, July 18, 2012 10:48:55 PM UTC+7, Wen wrote: > > Thanks Mitch, I had uploaded the configured ODK appregate to APp Engine. > I am now at the 'Using the Application' on > http://opendatakit.org/use/aggregate/. > For " you need to create an ODK username and password and grant it *Data > Collector* privileges. Do this on the *Site Admin / Permissions* tab", > where do I find the Site Admin/Permissions tab? > Thanks, > Wen > On Tuesday, July 17, 2012 3:14:48 PM UTC-4, Mitch wrote: > >> ...updated -- download the ODK Aggregate v1.2.0 file appropriate for your >> operating system, and then these instructions will make more sense: >> >> Download ODK Aggregate v1.N.N. >> Select the latest Featured release for your operating system. These >> downloads are wizard-based installers for the various operating systems. If >> you are running OSX, you must unzip the downloaded file before running the >> installer within it. Consider using a non-Featured release during forms >> development (to help us identify issues prior to our production release). >> >> Mitch >> >> On Tue, Jul 17, 2012 at 12:03 PM, Mitch S wrote: >> >>> These instructions are for 1.x I'll update the vN.N.N to v1.N.N. >>> >>> >>> >>> On Tue, Jul 17, 2012 at 11:58 AM, Wen wrote: >>> >>>> I am following http://opendatakit.org/use/aggregate/ instruction to >>>> install an App Engine Instance. At step #3 "Download *ODK Aggregate >>>> vN.N.N* , unzip >>>> and run it...", can someone tell me how to run it. I opened >>>> "ODKAggregateDeploy0.9.8.1" folder and don't know what to do. Thanks, >>>> Wen >>>> >>>> -- >>>> Post: opendatakit@googlegroups.com >>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>> >>> >>> >>> -- >>> Mitch Sundt >>> Software Engineer >>> University of Washington >>> mitchellsundt@gmail.com >>> >> >> >> >> -- >> Mitch Sundt >> Software Engineer >> University of Washington >> mitchellsundt@gmail.com >> >
