I need to put in place a constraint that will not allow both of these to be
0 - basically there is no way someone completing the form will now have at
least 1 child in the household.
i was hoping I could do it within question 2 but can't find a way of doing
it and so my only alternative is to add an additional page that will only
show if both q1 and q2 are 0(${q1} = 0 and ${q2} = 0) - on that page they
will be informed that this is not a possible combination and informed that
they need to go back and amend.
Hi Daniel,
Does using your formula in the constraint column for question 2 do what you
want?
Regards,
-Nathan
On Monday, February 25, 2013 1:43:31 AM UTC-8, Daniel Probert wrote:
> ello community i'm stuck again.
> I have the following questions:
> 1. How many Boys are in your household (integer)
> 2. How many Girls are in your household (integer)
> be 0 - basically there is no way someone completing the form will now have
> at least 1 child in the household.
> any thoughts on this.
> cheers
> dan
I ended up having to put in an error page to handle this that will only
show if you have enter 0 for both the previous questions. it works well.
thanks
dan
On Monday, 25 February 2013 18:26:25 UTC, Nathan wrote:
> Hi Daniel,
> you want?
> Regards,
> -Nathan
>> doing it and so my only alternative is to add an additional page that will
>> only show if both q1 and q2 are 0(${q1} = 0 and ${q2} = 0) - on that page
>> they will be informed that this is not a possible combination and informed
>> that they need to go back and amend.
>> cheers
>> dan
