Greetings ODK Community,
I have a working setup of ODKVoice and it works fine without any issue. However the data collected in ODKVoice through voice calls is recorded in the ODKVoice MySQL Database and it doesn't show up in the ODKAggregate. The same XFORM used by ODKVoice is also uploaded to ODKAggregate.
How can the two (ODKVoice and ODKAggregate) be integrated? Unfortunately I couldn't figure where and which settings need to be modified.
In advance, thank you very much for the support!
regards,
Baha
This is unsupported software.
I believe the URL for the ODK Aggregate instance where data is uploaded is
hardcoded in the GlobalConstants.java file:
https://code.google.com/p/opendatakit/source/browse/src/org/odk/voice/constants/GlobalConstants.java?repo=voice
regards,
Baha
