Dear Technical Crew,
We are in the conceptualization stage for the implementation of ODK
database for the management of data and we herewith wish to confirm if we
can be able to integrate and online payment platform into ODK using with
the use of either payment gates such as inter-switch.
Pls. could you kinldy advice on the possibility and cost.
Thank you once again and looking forward to hear from you!
Emmanuel Amile T.
Technical Director/Principal Consultant
E-tag Expert Resource Ltd
etagexpertresources@gmail.com
emmyamile4real@gmail.com
+234(0)8100997410, 08120914531,08071100381
It is unclear what you are trying to do.
The ODK project has 2 software versions, ODK 1.x Collect, and the ODK 2.0
tool suite.
ODK 1.x makes limited use of databases and stores collected data in XML
files.
ODK 2.0 is entirely database-centric.
Neither software version is designed to be intrinsically secure.
On Mon, Mar 13, 2017 at 2:05 AM, Amile Terhemba wrote:Dear Technical Crew,
Emmanuel Amile T.
+234(0)8100997410 <+234%20810%20099%207410>, 08120914531,08071100381--
