For some epidemiologists there is a difference between a question where a
"Choose1" type variable has null as a value (the question was not
answered), and the option, "Don't know." The problem in ODK collect (and on
web sites too) is that as soon as you tap on a choose1 response, you cannot
say, "Opps, that's not true, I need to unclick it." You can change your
choice, but if none of the other choices is suitable, you are left with
inaccurate data recording. Other than adding the option "Don't know" to
every choose1 type question, is there a way to deselect a radio button?
Hi Curtis,
On Wed, 13 Jun 2012, Curtis Broderick wrote:For some epidemiologists there is a difference between a question where
a "Choose1" type variable has null as a value (the question was not
on web sites too) is that as soon as you tap on a choose1 response, you
cannot say, "Opps, that's not true, I need to unclick it." You can
change your choice, but if none of the other choices is suitable, you
are left with inaccurate data recording. Other than adding the option
"Don't know" to every choose1 type question, is there a way to deselect
a radio button?
I think if you hold down your finger on the form, for a few seconds, a
popup menu appears which should let you clear the current page of the
survey, resetting to the "no answer chosen" state. Does that help?
Cheers, Chris.
Aptivate | http://www.aptivate.org | Phone: +44 1223 760887
The Humanitarian Centre, Fenner's, Gresham Road, Cambridge CB1 2ES
Aptivate is a not-for-profit company registered in England and Wales
with company number 04980791.
You da man Chris!!
2012/6/13 Chris WilsonHi Curtis,
a radio button?I think if you hold down your finger on the form, for a few seconds, a
survey, resetting to the "no answer chosen" state. Does that help?Cheers, Chris.
The Humanitarian Centre, Fenner's, Gresham Road, Cambridge CB1 2ESAptivate is a not-for-profit company registered in England and Wales
with company number 04980791.--
Curtis BRODERICK
Head of training and user support
Tél : + 33(0)1.53.02.40.61 06.15.33.57.37
Health Information System
-----------------------www.epiconcept.fr------------------------
Ce message et toutes les pièces jointes sont établis à l'intention
exclusive de ses destinataires et sont confidentiels.
Si vous recevez ce message par erreur, merci de le détruire et d'en
avertir l'expéditeur.
The information contained in the Email and any attachments is
confidential and intended solely and for the attention and use of the
named address(es). It may not be disclosed to any other person without
the express authority of EpiConcept, or the intended recipient, or
both.
If you are not the intended recipient, you must not disclose, copy,
distribute or retain this message or any part of it.
