How to have offline mapping in ODK Collect? Is it possible to do so? If
yes, what it is the process to have an offline mapping in ODK Collect?
Also, how to download data's from odk aggregate after synchronizing it in
google app engine into PostgreSQL?
Santosh,
GeoODK has built that ability into there version on ODK Collect. I am looking into the same thing..........except I am looking to use building overlays to assist mapping when over canopy. as I said I am just looking into it as well so I will let you know if it turns out well as a viable solution.
http://geoodk.com/index.php is their URL...........good luck
On Sunday, January 25, 2015 at 5:44:40 AM UTC-5, santosh sangachhen wrote: > How to have offline mapping in ODK Collect? Is it possible to do so? If yes, what it is the process to have an offline mapping in ODK Collect? > Also, how to download data's from odk aggregate after synchronizing it in google app engine into PostgreSQL?Thank you John, ya i also have used GeoODK just got familiar with it
somedays ago but now i'm having trouble with map conversion, it seems that
geoodk requires .mbtile format and i'm using tilemill to convert .tif files
into .mbtile but i'm not being able to convert it, either it takes too long
time or it fails in the middle. So, thought to ask if there is any other
alternatives.
Hope, you'll find the solution soon enough, and will let me know too. So,
hoping to hear from you soon.
Thanks, once again.
